Brief Description: Fabricated rudder stops and riveted bulkheads...
Today I fabricated the rudder stops from aluminium angle stock, see image 1. Following this I riveted together bulkheads F-706 through F-712, riveted together the F-728 bellcrank channel, the F-729 bellcrank rib as well as riveting the F-711 and F-712 to the tail cone skin, see image 2. I finished up the day's work session be riveting the fuselage center section rib nut plates to the ribs, see image 3.
